Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Arlo Q multiple logins
Reply
Discussion stats
  • 3 Replies
  • 3760 Views
  • 0 Likes
  • 3 In Conversation
Tammy18
Is this still not resolved? it is now 2017. I just switched out my Arlo Netgear for the ArloQ as the Arlo netgear didn't have an option i needed the most. But Arlo had multiple logins and now we dont have it
3 REPLIES 3
JamesC
Community Manager
Community Manager
Tammy18,
When swapping to or adding a new device, you can add the new device to your existing Arlo account (using the same login). Can you give us more details on the issue you are describing?
JamesC
Tammy18
I mean, login  from my husband phone to check on an alert will result in kicking me off my app.
jguerdat
Guru Guru
Guru
The same thing that worked on the wireless cameras works for the Q cameras, too. Use Settings, Grant Access.
