Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Arlo Q will not sync and gets hot
Reply
Discussion stats
  • 1 Reply
  • 3846 Views
  • 0 Likes
  • 2 In Conversation
jgiffin
Follower
Follower
I have had the Arlo Q for 6 months. Had been working great, but just now stopped syncing to network. I have gone through the install procedure multiple times with no success. After approximately 5 minutes of this, the unit starts to get hot. The device should last longer than 6 months. Is there a return/replacement policy?
1 REPLY 1
jguerdat
Guru Guru
Guru
There's a 1 year warranty on all Arlo cameras. Your documentation should show this.
The Q cameras do run warm but not hot. What's your definition of hot? Have you tried measuring the temp using a laser or contact thermometer? I seem to recall that a normal temp is around 120 degrees F.
