Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
How can set a mode that uses both Arlo Q and Arlo Pro
Reply
Discussion stats
  • 1 Reply
  • 1467 Views
  • 0 Likes
  • 2 In Conversation
RobBeaver
Follower
Follower
How do I setup a mode that works across both my Arlo Pro and Arlo Q? For example, if my Arlo Pro detects motion start recording from my Arlo Q. I see options to setup modes through my base unit for the Arlo Pro and through the Arlo Q camera but not an overlap. Thanks for any pointers. I am hoping I have missed something and that this isn't a "feature".
Rob
1 ACCEPTED SOLUTION
Accepted Solutions
TomMac
Guru Guru
Guru
Rob
You can not... the Q cameras and the Arlo based cameras act as separate units.... each with their own arming, schedule, etc.
No different is you had two bases..it would cact the same way
But, this has been requested in the future...so look it up in the request area and add kudos. ( more kudos, more likely to happen )
Morse is faster than texting!
1 REPLY 1
TomMac
Guru Guru
Guru
Rob
