Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Newly defined activity zones can not be saved
Reply
Discussion stats
  • 3 Replies
  • 3088 Views
  • 0 Likes
  • 3 In Conversation
metsch
Newly defined activity zones can not be saved. Movement detection is carried out in the "Everywhere" sector.
3 REPLIES 3
Hula_Rock
Prodigy Prodigy
Prodigy
Just to make sure.... are you hitting the save button after each one is created.  I just redefined my 3 zones and saw them all in three defined colors.
metsch
I have saved the zones. Furthermore, the entire visible zone is recordet.
Greetings
jguerdat
Guru Guru
Guru
Don't forget that once you create the zones you also have to enable them in your modes/rules.  By default the whole scene is used unless you specify the zones in your rules.
