Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
No connecting to wifi
Reply
Discussion stats
  • 4 Replies
  • 2573 Views
  • 1 Like
  • 2 In Conversation
Sally4215
Tutor
Tutor
The devise failed to connect. I have rebooted, restarted the devise n nothing. Works for a couple hours n gone. Wifi is great. Considering I am monitoring an elderly mother. I need the camera to work. Looks like it’s a waste of monie
4 REPLIES 4
jguerdat
Guru Guru
Guru
You give up easily. First, try a reset of the camera by holding the reset button until the LED flashes amber. Make sure the WiFi is using WPA2 encryption, not WEP. Also, make sure you're on the same WiFi (or network) as the camera is trying to connect to.
It's also possible that it's a bad camera - swap at the store.
Sally4215
Tutor
Tutor
I have done that 3 times already and not connecting. One camera works just fine, so I set up both cameras side by side n still not working. So disappointed
jguerdat
Guru Guru
Guru
If it's not working, get it replaced. Why beat your head against a wall? Swap at the store or open a case with support here. There's absolutely no reason to be disappointed - fix it!
Sally4215
Tutor
Tutor
They both were replaced today
