The Arlo Q goes through setup ok with the chime but does not discover the device.
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The Arlo Q goes through setup ok with the chime but does not discover the device. In meantime the LED turns solid blue. But my Samsung phone continies to show Arlo trying to connect to my device.
Thanks for help.
- Related Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Exit setup and see if the camera shows up in the Devices tab. I've had issues with the discovery phase only to have it eventually show up.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for the reply.
Not sure what or where is the Devises tab ??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It does not show up in the Arlo menu under Devices . The menu says "Add Device".
When I plug in the camera the light is steady amber then changes to purple then to steady blue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Are you using the same WiFi band on your phone as what you're trying to connect the camera to? That is, are both connecting to the 2.4GHz or 5GHz bands? It's possible that's a part of the issue. Also, are there any non-alphanumeric characters in either your SSID or passphrase? Your WiFi must use WPA2 in addition.
Even so, try resetting the camera by pressing the reset button until the camera LED flashes amber. Let it boot and try again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Your last suggestion worked !
Thanks for your help. This was a test at home. I need to take the camera to my boat and set it up there. There is, of course, a different WIFI system there. Do you have any suggestions for the setup at this different location?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
For the new WiFi connection, use Settings, My Devices, your camera, WiFi Network and follow the bouncing ball to connect to the new network.
Activity Zones
1 -
Apple TV App
1 -
Arlo Mobile App
20 -
Arlo Pro
1 -
Arlo Q
30 -
Arlo Smart
2 -
Arlo Web and Mobile Apps
1 -
Arlo Wire-Free
5 -
Before You Buy
108 -
Fehlerbehebung
1 -
Firmware Release Notes
15 -
IFTTT (If This Then That)
7 -
Installation
352 -
Online and Mobile Apps
135 -
Online und mobile Apps
1 -
Other Discussions
1 -
Service and Storage
2 -
Smart Subscription
1 -
SmartThings
5 -
Troubleshooting
1,112 -
Videos
50
- « Previous
- Next »
