Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Arlo light won't sync
Reply
Discussion stats
  • 4 Replies
  • 10383 Views
  • 1 Like
  • 3 In Conversation
arion316
My 1st light synced just fine and is working great.  I went to sync my 2nd light the next day and it won't discover it after trying about 6 times.  I scanned the QR code and I pressed the sync button for 5 seconds and it blinked blue but then it just fails to discover the light. Just says "Looking for your light" and then finally says "Association failed".  Any help would be appreciated.
1 ACCEPTED SOLUTION
Accepted Solutions
JamesC
Community Manager
Community Manager
arion316,
Try unplugging the bridge, plug back in, allow the bridge to come online and then attempt to sync the second light. Do you still see the same behavior?
JamesC
4 REPLIES 4
steve_t
Master Master
Master
How close/far away is your light from the bridge when you try to sync?
arion316
Only about 6ft, same room
JamesC
Community Manager
Community Manager
arion316,
JamesC
arion316
James that seemed to do the trick, thanks for that!
Discussion stats
  • 4 Replies
  • 10384 Views
  • 1 Like
  • 3 In Conversation
