Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Can the Arlo Pro 2 security system bought in another country chargeable in Australia using 240 volt
Reply
Discussion stats
  • 6 Replies
  • 5068 Views
  • 4 Likes
  • 4 In Conversation
Nighthawk9988
Hi there
I am most interested in buying the Arlo Pro 2 bundles but I can’t get the upgraded version 1080p within Australia so I thought I could buy from overseas. The only problem I am worried about is that I can not charge the batteries from my AC power outlet because we use 240v in Australia and not 110v and fear that I will blow the charger up. Can I use overseas version in Australia?? Does it have a transformer for multiple voltages?? I hope you can help me
Kind Regards
David
1 ACCEPTED SOLUTION
Accepted Solutions
TomMac
Guru Guru
Guru
The adapter for ac that I'm looking at right now shows an input of 100-240v
This was in the Pro2 box I received
Morse is faster than texting!
6 REPLIES 6
brh
Master
Master
@Nighthawk9988
I believe that the Arlo Pro 2 comes with a universal power adapter that will work on 240V AC although if your outlets are like the ones in the UK, you will need a travel adapter to make the pins work.
I don't know which is better, purchasing from USA or UK.
Brian
TomMac
Guru Guru
Guru
Nighthawk9988
Thank you very much for the info!
Nighthawk9988
Thank you for your help advice as well! Now I have to decide whether I should buy from the US or the UK. Either way I will need a travel adapter to suit AUSTRALIA pin
Nighthawk9988
Thank you so much Brian!!!
Kpatel7899
Discussion stats
  • 6 Replies
  • 5069 Views
  • 4 Likes
  • 4 In Conversation
