Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Arlo Smart Home Security Light - NEW Smart, Wire-Free Lighting Solution - Spring 2018
Reply
Discussion stats
  • 1 Reply
  • 2376 Views
  • 0 Likes
  • 2 In Conversation
BretD
Arlo Employee Retired
Arlo Security Light - Coming Spring 2018:Arlo Security Light - Coming Spring 2018:
Coming Spring 2018-
Arlo® Outdoor Smart Home Security Light is a 100% wire-free, smart-controlled, and weather-resistant LED light that helps improve outdoor safety by alerting you when something’s happening around your home.
With the Arlo Security Light, you can light up your front porch, driveway, deck, backyard, and other outdoor areas around your home with customizable lights. Position the Arlo Security Light virtually anywhere with the easily adjustable mounts. Powered by removable rechargeable batteries or an optional solar panel.
The Arlo Security Light will automatically turn on whenever motion is detected, but motion sensitivity can be easily adjusted for different areas to fit specific security needs. When out of town, it is simple to set a schedule to turn lights on and off to give the illusion that someone is home. Setting up a schedule can also be done remotely through the free Arlo app.
We would love to answer your questions or comments about the Arlo Security Light. Visit our new Arlo Security Light forum or reply to this post and give us your feedback.
See the Arlo Security Light product announcement page.
____
Please click KUDOS or REPLY If you found this helpful.
1 REPLY 1
XJW
Apprentice
Apprentice
Please ensure that this can be used as a motion sensor to trigger other cameras. It is often the case that the Camera position is good in one location and the motion sensor is better in another.  eg A camera facing the front gate with a motion sensor pointing parallel to the gate.  If it is cheaper than a camera I would use it as a motion sensor only.  Please ensure that it can be programmed to not use the light.  I would prefer to save the battery.
Related Labels
Discussion stats
  • 1 Reply
  • 2377 Views
  • 0 Likes
  • 2 In Conversation
