Range Extender vs Ethernet Cable
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I'm trying to resolve a problem with my Arlo cameras. As of right now, my wireless router and Arlo base station are in one corner of my house, and the place I need to mount my cameras (exterior of garage) is at the far opposite corner. It isn't that big of a house, but the signal becomes very weak at that distance, perhaps because of all of the interior walls in between. So now I am trying to figure out a way to increase my signal strength.
Two things I am thinking about trying:
1. Use a WiFi Range Extender that plugs into a wall outlet, then plug my base station into Range Extender, or
2. Buy about 100' ft of ethernet cable and run it all the way from that corner bedroom modem to the base station at a spot closer to garage.
Any pros or cons these ideas?
I have already bought a range extender (Netgear EX-6100) and hoped this would work because it would be the easiest solution and I wouldn't have to string a cable halfway across my house. I've just never used one before and didn't know if they were a gimmick or if they really worked. And if they do work, is the signal strong enough to operate the cameras from.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Both are usable options.... As long as the extender like you say 1) a strong enough signal and data thruput 2) a Ethernet port
problem is you won't know till you try it (but since u all ready do own it why not try
just remember the min speeds to work well is 1mb thru
Morse is faster than texting!
Accessories
4 -
Activity Zones
1 -
Amazon Alexa
1 -
Apple HomeKit
2 -
Apple TV App
9 -
Applications mobile et en ligne
1 -
Apps
4 -
Arlo Go
3 -
Arlo Mobile App
462 -
Arlo Pro
36 -
Arlo Pro 2
1 -
Arlo Q (Plus)
3 -
Arlo Smart
121 -
Arlo Web and Mobile Apps
18 -
Arlo Wire-Free
30 -
base station
1 -
Batteries
529 -
Before You Buy
731 -
Can't view cameras live at all
1 -
Dépannage
1 -
Détection de mouvements
1 -
Fehlerbehebung
1 -
Firmware Release Notes
93 -
Google Assistant
1 -
Hardware
1 -
home security
1 -
IFTTT (If This Then That)
105 -
Installation
1,953 -
Iphone 14 pro
1 -
Live view
1 -
Modes and Rules
1 -
Motion Detection
2 -
Object Recognition
3 -
Online and Mobile Apps
983 -
Online und mobile Apps
1 -
Order Not Going Through... help please!
1 -
Other Discussions
1 -
Partner Integrations
4 -
Security
1 -
Service and Storage
14 -
Smart Subscription
3 -
SmartThings
71 -
Troubleshooting
8,544 -
Videos
233 -
Vidéo
2 -
Warranty & Contracts
2
- « Previous
- Next »
