Arlo false triggering from sunlight reflecting off passing cars
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have my camera pointed toward the driveway, and every time a car drives by, the reflection from the sun hitting the car creates a flash of light cast across my driveway where I have my camera aimed. This triggers the camera. I made sure the car itself in the street is not in the field of vision on the camera. I've lowered the sensitivity and it makes no difference. Any suggestions?
- Related Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Where are you adjusting the sensitivity? It must be in your modes/rules, not in the Motion Detection Test.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Correct. I adjusted in the modes
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Could be refelctions from the street that are bouncing off something else. Post a screenshot.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have the same issue recently with sunlight setting off false triggers , this seems to happen all the time now on 3 cameras I have outside .
I have had the cameras for about 2-3 years now and they are in exactly the same positions when I first installed them and they never used to get so many false triggers until the last 3-6 months . I have even turned down the sensitivity a lot still get so many each day . I assume this is from some update net gear has recently done to the camera setting ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Getting false triggers one after another from the sun light and shadow on the side of the house. Had Cams for 2 years and as we approch October, November and December the sun is more on an angle and tends to shadow about half of the wall on my house. Normaly the sun in the summer is straight above the roof and the entire erea where the cam is loacted is shadowed completley and the false trigger happens much less. I can not position the camera any other way I have tried many options to allow the vew of the front door and this shadow sun issue still happens.
I get a flash but there is not bird,bug, glare nothing but the sun in this posistion that is causing this issue. Netgear please step it up this needs to be fixed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
cody9910,
Have you tried to reboot the base station and test again?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes turned off base, camera and swapped cameras they all do the same thing nothing helps. Very frustrating, I am now to a point where I have to turn the camera off at this time of year and certain times of the day to avoid the annoiance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
cody9910,
You can create a custom schedule for the camera to try and avoid the shadow for a few moments and then have it reactivate. This should help with the sun and the false alert.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I am aware of the scheduling feature but dont you think this is defeating the entire purpose of having the security around? what I can't understand is why netgear will not make this right. There is a fundimental flaw with cameras and there are so many complaints about false triggers. For the cost of this system they should be doing somthing to fix the issues. In the begining I recomended this camera but until netgear fixes these issues without shutting down the camera. I can no longer recomend this system.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have the same issue and created another post about it photos here https://community.arlo.com/t5/Arlo-Pro/Arlo-False-Triggers-with-Sunlight-Shade/m-p/1638498
Seems to me this have been some sort of update to the camera algorithm update and they have not addressed or fixed yet . Really anoying issue and I have to end up turning off the cameras at times which defeats the purpose of the system .
Im supprised no one from Netgear has made a memo or issued a notice about this issue and they keep sweeping it under the rug by saying try turning it of and on or swapping camera etc .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I am getting false positives from the morning sun on my patio. I just purchased the Arlo Pro 2 system. I have turned down the brightness and even turned off the mic. I have swapped out three camerias and they all had the same problem. Has anyone resolved this issue?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have you cnaged the sensitivity setting in your modes and rules and then saved them? Some folks think the temporary setting in the motion detection test will work but that's the wrong place.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @The_Coach
You can try and adjust the sensitivity down by 1% until you get the desired results. Have you made sure your cameras & base station are up to date on the latest firmware?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I already have the brightness down to 0%. How do you update the camera software. The base station updated itself when I initially installed it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The 0% is set in your modes and rules, right? Have you checked to verify you saved the changes?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
i tested it with three camerias. It is the sun. we had a cloudy day today and we had no problems. I will need to put some type of visor on the camera to reduce the sun glare.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Or start turning down motion sensitivity until you minimize false detections while still getting the ones you need.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @02redcavi
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @02redcavi
What troubleshooting steps have you performed so far? I don't want to suggest anything you may have done.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have you tried to remove the cameras from Settings > My devices the re-add them?
Make sure your cameras & base station are up to date on the latest firmware. I have attached the link here for you - Firmware release Notes
Accessories
4 -
Activity Zones
1 -
Amazon Alexa
1 -
Apple HomeKit
2 -
Apple TV App
9 -
Applications mobile et en ligne
1 -
Apps
4 -
Arlo Go
3 -
Arlo Mobile App
462 -
Arlo Pro
36 -
Arlo Pro 2
1 -
Arlo Q (Plus)
3 -
Arlo Smart
121 -
Arlo Web and Mobile Apps
18 -
Arlo Wire-Free
30 -
base station
1 -
Batteries
529 -
Before You Buy
731 -
Can't view cameras live at all
1 -
Dépannage
1 -
Détection de mouvements
1 -
Fehlerbehebung
1 -
Firmware Release Notes
93 -
Google Assistant
1 -
Hardware
1 -
home security
1 -
IFTTT (If This Then That)
105 -
Installation
1,953 -
Iphone 14 pro
1 -
Live view
1 -
Modes and Rules
1 -
Motion Detection
2 -
Object Recognition
3 -
Online and Mobile Apps
983 -
Online und mobile Apps
1 -
Order Not Going Through... help please!
1 -
Other Discussions
1 -
Partner Integrations
4 -
Security
1 -
Service and Storage
14 -
Smart Subscription
3 -
SmartThings
71 -
Troubleshooting
8,544 -
Videos
233 -
Vidéo
2 -
Warranty & Contracts
2
- « Previous
- Next »
