Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have 5 cameras, 2 Arlo with base was original purchase and then have added 3 Arlo pros. All works great except for one camera! It's one of the original Arlo's and it senses motion and sends the alert, but doesn't record. It will record when I do it manually. Have tried to read other posts and see it happens alot, however, I never came across the solution 😮 Please help, thanks
Solved! Go to Solution.
Labels:
- Related Labels:
Troubleshooting
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Update!! Great news, did contact customer support and they were awesome!!! I had tried removing device and then re-syncing, but it didn't work. This time when I did it, it worked 👍 Apparently, if the camera is facing anything reflective (window, mirror, etc.) it can cause it to happen. Thanks everyone 😊
5 REPLIES 5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Any chance for that cam you have sensitivity set to 0, or rule for that cam says to do nothing if motion is detected?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you so much for replying. Actually, I have the sensitivity set to 100 % and the rule set to record. All other 4 cameras work fine. It's just this one. I have even removed it and reactivated it, but still no luck.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
and assume putting it in location one of the working cams has doesnt change anything?
Then sounds like something for technical support using one of the methods shown by clicking on the contact support button on each forum page.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yep, just this one "special" camera 😉 Will contact technical support, thank you!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Related Labels
Accessories
4 -
Activity Zones
1 -
Amazon Alexa
1 -
Apple HomeKit
2 -
Apple TV App
9 -
Applications mobile et en ligne
1 -
Apps
4 -
Arlo Go
3 -
Arlo Mobile App
455 -
Arlo Pro
36 -
Arlo Pro 2
1 -
Arlo Q (Plus)
3 -
Arlo Smart
119 -
Arlo Web and Mobile Apps
18 -
Arlo Wire-Free
30 -
base station
1 -
Batteries
529 -
Before You Buy
727 -
Can't view cameras live at all
1 -
Dépannage
1 -
Détection de mouvements
1 -
Fehlerbehebung
1 -
Firmware Release Notes
93 -
Google Assistant
1 -
Hardware
1 -
home security
1 -
IFTTT (If This Then That)
105 -
Installation
1,951 -
Iphone 14 pro
1 -
Live view
1 -
Modes and Rules
1 -
Motion Detection
2 -
Object Recognition
3 -
Online and Mobile Apps
983 -
Online und mobile Apps
1 -
Order Not Going Through... help please!
1 -
Other Discussions
1 -
Partner Integrations
4 -
Security
1 -
Service and Storage
14 -
Smart Subscription
3 -
SmartThings
71 -
Troubleshooting
8,524 -
Videos
233 -
Vidéo
2 -
Warranty & Contracts
2
- « Previous
- Next »
