- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Am I missing something? Is it possible I messed up some setting somewhere?
Solved! Go to Solution.
- Related Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
OK, so I am having an issue with one of my cameras outside. it is producing like a pink to red colorizing kind of thing how do I fix this?I have attached an example thanks
and also i thought arlo cameras are waterproof ? i opened uo mine to change the batteries and it had water all in the battery compartment.
base station details:
firmware 1.9.4.0_15548
model VMB3010
camera in question:
firmware 1.2.1181
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The pink hue can sometimes be remedied by opening and closing the battery compartment to reset it or others have said they use the camera upside down and select the Invert Camera setting. It's a fault with an IR filter. You should be able to have the camera replaced under warranty.
These cameras are IP65 water resistant but cannot be submerged etc. The majority of the time when water has got in, it's because the user has failed to close the battery compartment door adequately
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
MODEL ARO PRO
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Can you post a screenshot? The pink picture problem of the original Arlo cameras doesn't affect the Arlo Pro cameras AFAIK because the Pro doesn't have the same mechanical IR filter inside it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The " red" cam is a hardware issue , either return it or contact Netgear for warranty
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You will always need to make the contact, regardless of the product. Use the Contact Support link at the bottom here to open a case.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have the same exact problem. I tried everything recommended by the community but still getting red tint on one of my three cameras. These cameras are New right out of the box.
i open a case with support, no one has gotten back to me . Tried calling support , no one picked up. Looking for some help here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Called support , picked up right away, no wait time, support open a RMA, now waiting delivery of replacement, great service and a job well done
hope Netgear continues to stick by their products, I will recommend and buy more
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I am having the camera tinted pink/red problem like many other people.
Purchased March of 2016.
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes, as in all the other similar threads here, the only solution is to open a case with support here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Arlo Pro is so much better than Arlo HD wirefree. It's worth it to pay a little bit extra for it. No pink tint problem guaranteed because the camera doesn't have the mechanical filter to get stuck
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I bought these cameras in a 5 pack with the base station included.
2 of the cameras work properly showing color images in the light, and black and white night vision when it is dark.
2 of the 5 cameras suffered from this pink image problem when the room is brightly lit. They work normally when the lights are out, using night vision IR.
1 of the 5 cameras shows color images in normal lighting, but can't display any night vision. I can see the IR lights come on in front of camera around the lens, but the camera is unable to switch into night vision mode, and everything on the camera image is dark.
So 3 of 5 cameras in the box are defective. I've been on the chat with Arlo and on the phone with Arlo support. They tried to ship me 1 of the cameras in the from the chat session, but they shipped it to the wrong address. On the 2nd and 3rd broken cameras, they noticed the the first camera shipped to the wrong location.
Long story short, if you have the pink or red tinted image, Arlo will have to ship you a replacement camera, at least according to the phone support. Not sure if they will work, but I'm hoping.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Within the store's return policy time, you generally have the ability to swap at the store, too.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Bought the standard Arlo Security System with 3 cameras and have had nothing but fiddly behavioir from it since installation.
See the screenshot for this morning's adventure.
Camera one (front of house) - fine
Camera two (front of house) - grayscale (still in nightvision mode?)
Camera three - porch (pink!)
Unless support responds to my ticket soon, this system will be boxed and returned.
I don't have time for climbing ladders every 2 days to reset cameras or bring them back to the base to re-synch.
I don't mind troubleshooting, but I did not anticipate this much trouble in this short a time frame with a new system with 2 out of 3 cameras acting up,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Arlo HD? It's an IR filter getting stuck. You can try to reset the camera by removing the batteries and reinserting them. If that doesn't work, turn the camera upside down and change from bright light to dark (covering the lens with your hand) and back to bright. Some people find if they mount the camera upside down and use the settings to invert the image, it works fine. Otherwise, contact support at the bottom of the page and open a ticket. They should replace the camera for you as it's a known fault
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
As suggested in the many threads here abou the same issue, open and close the battery door to see if it helps. If not, open a case with support using the Contact Support link at the bottom here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have one of my cameras is showing a pink image/video. I contacted support and they admitted that the camera was defective and that there were many other customers with the same issues but they told me my camera was out of warranty so the could not help me.
Any one have a suggestion?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
pull batteries.... replace.
Cover lens to get the IR to come on and then "rap" it on the desk ( not overly hard )
the ir filter is suck in place and sometimes you can knock it free..test in lighted area to see if ok
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
My system of four Arlo wire free and Arlo Q has proved to be a big problem. Two wore free had pink views within a few days after installation. Finally after long discussion had the customer rep authorize replacement. Recieved one replacement and it will not sync. Spent hours trying. Customer rep wanted to do all kinds of reboots, change battereis etc. I finally mentioned that the original cameras did sync easily and this replacement is defective. Hope to get a replacement. Have spent way too much time for a system with issues. Working with the customer reps is a nighmare. Don't know how much more to endure before finally dumping everything. Waste of $600. Only had this for three weeks.
Accessories
4 -
Activity Zones
1 -
Amazon Alexa
1 -
Apple HomeKit
2 -
Apple TV App
9 -
Applications mobile et en ligne
1 -
Apps
4 -
Arlo Go
3 -
Arlo Mobile App
462 -
Arlo Pro
36 -
Arlo Pro 2
1 -
Arlo Q (Plus)
3 -
Arlo Smart
121 -
Arlo Web and Mobile Apps
18 -
Arlo Wire-Free
30 -
base station
1 -
Batteries
529 -
Before You Buy
731 -
Can't view cameras live at all
1 -
Dépannage
1 -
Détection de mouvements
1 -
Fehlerbehebung
1 -
Firmware Release Notes
93 -
Google Assistant
1 -
Hardware
1 -
home security
1 -
IFTTT (If This Then That)
105 -
Installation
1,953 -
Iphone 14 pro
1 -
Live view
1 -
Modes and Rules
1 -
Motion Detection
2 -
Object Recognition
3 -
Online and Mobile Apps
983 -
Online und mobile Apps
1 -
Order Not Going Through... help please!
1 -
Other Discussions
1 -
Partner Integrations
4 -
Security
1 -
Service and Storage
14 -
Smart Subscription
3 -
SmartThings
71 -
Troubleshooting
8,544 -
Videos
233 -
Vidéo
2 -
Warranty & Contracts
2
- « Previous
- Next »
