- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have 2 cameras that will drain batteries and go offline in a couple days. I have gone through the procedures and has the same results. The firmware is current 1.2.16720. I have 4 cameras total and the same 2 have problems. The cost of the set is disappointing not to last more than a few years.
Solved! Go to Solution.
- Related Labels:
IFTTT (If This Then That)
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I followed the procedure of removing and readding the cameras again and this time, new updates were loaded to the cameras. This was a couple weeks ago and the batteries have not drained(knock on wood). Hopefully, this fix is what was needed. Thanks for the help!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Don't know why , but can say its not normal... my run 3-4 months depending on usage.
I would take the troubled cameras down and then use REMOVE device ( delete them ) ... then bring them back as new.
This will rebuild the modes.
Check if the led illuminators are staying on in a dark room, you will see the redish glow from them around the lens ( when recording or live viewing )
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have done that before and had the same results. There is no way to tell if the cameras are faulty?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
svchirco,
What is the signal strength like for the two cameras having the issue? You might try swapping the cameras that are going offline with the other 2 that are behaving normally to see if the issue follows the location or the camera.
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The strength is the same since I installed a couple years now. I did the remove and added back and it worked for a couple days and then both go offline again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Accessories
4 -
Activity Zones
1 -
Amazon Alexa
1 -
Apple HomeKit
2 -
Apple TV App
9 -
Applications mobile et en ligne
1 -
Apps
4 -
Arlo Go
3 -
Arlo Mobile App
462 -
Arlo Pro
36 -
Arlo Pro 2
1 -
Arlo Q (Plus)
3 -
Arlo Smart
121 -
Arlo Web and Mobile Apps
18 -
Arlo Wire-Free
30 -
base station
1 -
Batteries
529 -
Before You Buy
730 -
Can't view cameras live at all
1 -
Dépannage
1 -
Détection de mouvements
1 -
Fehlerbehebung
1 -
Firmware Release Notes
93 -
Google Assistant
1 -
Hardware
1 -
home security
1 -
105 -
Installation
1,953 -
Iphone 14 pro
1 -
Live view
1 -
Modes and Rules
1 -
Motion Detection
2 -
Object Recognition
3 -
Online and Mobile Apps
983 -
Online und mobile Apps
1 -
Order Not Going Through... help please!
1 -
Other Discussions
1 -
Partner Integrations
4 -
Security
1 -
Service and Storage
14 -
Smart Subscription
3 -
SmartThings
71 -
Troubleshooting
8,543 -
Videos
233 -
Vidéo
2 -
Warranty & Contracts
2
- « Previous
- Next »
