Low Battery Issue
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Installed less than a month ago, and have to already replace the batteries. Dont have motion detection on regularly to drain batteries. All five cameras went out on the same day, exactly one day after I was unable to connect to the hub remotely. Were the camera batteries unneccessarily drained during this one day period when the hub was unavailable to connect?
- Related Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello Shogun,
Thank you for your post. We have had a hand full of customers reporting inaccurate battery level readings regarding their cameras. This was caused by a programing issue that was recently discovered by our software team. Cameras that were positioned outside in cold temperatures were the most effected. If your cameras were placed outside in the cold temperature please try the following listed below.
Bring the cameras inside to room temperature and remove the batteries. Let the batteries warm to room temperature before placing them back inside the cameras. This will allow the batteries to regain their maximum charge and allow for a more accurate battery reading from the camera
If your cameras were not in the direct cold please follow the steps listed above to reset your battery reading levels.
If you continue to experience problems with your batteries please reply back to this thread and I will further assist you.
The Arlo Team
David
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
After bringing my cameras inside and getting the batteries to room temperature, I still have a low battery warning.
Please let me know what I am to do now.
Thank you,
Adam Molinaro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
One of our 2 cameras showed low battery after 6 weeks, and died when the other was 3 bars.
Replaced the batteries, but checked the 4 batteries. One was <1 V, and the other 3 normal, so one failed battery made camera stop working.
These are the original batteries.
Watch for one bad cell if your cameras fail early.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
However, the camera with no motion detection and is not used but maybe once every 3-5 days for 2 mins shows the batteries need to be replaced.
Is there an update for this or should I send the camera back?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
What camera firmware versions do the cameras have? Look in Settings, Camera Settings and scroll down to the bottom for each camera. If they aren't current (1.2.2412), open and close the battery door and watch the front LEDs for update status. Perhaps the one camera isn't up to snuff and replacing the batteries will force the upgrade.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I swapped batteries with another camera, and the batteries from the defective camera were showing as almost completely used in different camera as well, so the defective camera is using much more battery power than normal at an idle state.
I bought new batteries today and replaced them. The camera was offline after the replacement for 2 reboots, then I noticed that it needed to be re-paired with the base while in the same room as the base unit.
I guess I'll keep an eye on it and update you all in another couple weeks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I deleted the camera from the paired devices, re-synced it, it worked for about 10 minutes. Since then I got "Offline" so the camera was not accessible.
Today I got, "It's time replace your batteries." This camera now shows 6%. I JUST replaced the batteries Wednesday.
I have a ticket in with NETGEAR L2 support (Allen) and said he said would call me when he is available, but he hasn't called me back since their last missed attempt (Wednesday). I have to say I'm not liking my experience with NETGEAR support so far.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
There's extra consumption when users first start using the system. Once over that hump, battery life generally gets much better. Consider the use of rechargeable batteries as referenced in the Buying Tips and Options forum.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Lamorena619 wrote:
Where can I get firmware updates
Firmware updates are now fully automatic... If the base requires an update ( meaning there is one that wasn't done ) usu a reboot via the power button will trigger it
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You've got it right. Try resetting the camera by opening and closing the battery door. Could be a defective camera by also try swapping with another camera if you have one. If the trouble follows the camera, create a trouble ticket.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
We are getting low battery screens for two of our cameras despite changing the batteries. I tried to restart the device from the app, but no change. One is an outdoor camera and the other is indoors. What should I try next?
Thank you!
Sharon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Sometimes using the power switch gives you a resolution that using the restart button doesn't since it actually powers everything off, clearing memory, etc. Worth a try. What batteries are you using? There's always the chance that you got a bad batch, regardless of manufacturer. Did they instantly show low battery or did it take some time? Roughly how much recording and live viewing has been done on each, in minutes?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Gregory143,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
rdt303,
Because only one camera is affected, this could be due to poor signal strength between the camera and base station. One way to isolate this further is to place the affected camera in a location with an unaffected camera and see if the behavior follows the camera.
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Firmware 1.2.10342
Out of the box the batteries lasted a couple of months. Since then after a couple days I get a low battery alert after putting in fresh batteries. Camera is useless if we can't even go on vacation without wondering if the camera will even last until we get back. From all the comments I have found online this is a known problem with this device and no one has seemed to be able to find a resolution.
Accessories
4 -
Activity Zones
1 -
Amazon Alexa
1 -
Apple HomeKit
2 -
Apple TV App
9 -
Applications mobile et en ligne
1 -
Apps
4 -
Arlo Go
3 -
Arlo Mobile App
462 -
Arlo Pro
36 -
Arlo Pro 2
1 -
Arlo Q (Plus)
3 -
Arlo Smart
121 -
Arlo Web and Mobile Apps
18 -
Arlo Wire-Free
30 -
base station
1 -
Batteries
529 -
Before You Buy
731 -
Can't view cameras live at all
1 -
Dépannage
1 -
Détection de mouvements
1 -
Fehlerbehebung
1 -
Firmware Release Notes
93 -
Google Assistant
1 -
Hardware
1 -
home security
1 -
IFTTT (If This Then That)
105 -
Installation
1,953 -
Iphone 14 pro
1 -
Live view
1 -
Modes and Rules
1 -
Motion Detection
2 -
Object Recognition
3 -
Online and Mobile Apps
983 -
Online und mobile Apps
1 -
Order Not Going Through... help please!
1 -
Other Discussions
1 -
Partner Integrations
4 -
Security
1 -
Service and Storage
14 -
Smart Subscription
3 -
SmartThings
71 -
Troubleshooting
8,544 -
Videos
233 -
Vidéo
2 -
Warranty & Contracts
2
- « Previous
- Next »
