Motion not detecting people
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Related Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It probably is just that with such high background heat, the IR signal of people is not easily distinguished. Does it work better again when it's cooler outside?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have you turned up your motion sensitivity? And figured out how to save the new sensitivity setting? The menu isn't that intuitive
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
the motion detection system used in battery operated cams is good for detecting movement across the cam but not very good for movement into the cam.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I've found arm movements don't work well to trigger detection, even at high sensitivity settings. They're relatively small compared to your body and the IR signature will be smaller, too.
Post screenshots of your cameras' views for suggestions.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
https://ibb.co/e2MNPk
https://ibb.co/kBtxqQ
https://ibb.co/g17Jx5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The first two have a couple of issues - 1) the cam should be rotated down to eliminate the street which will reduce false detections and 2) distance to the subject since there's a significant amount of vector more or less directly at the camera. Repositioning the cameras for more side to side motion would help as would being closer to the action. People only detect out to 20-25 feet and then there's the startup lag to the system of at least two seconds.
Number 3 is primarily a system lag issue altho rotating it down some may help.
Accessories
4 -
Activity Zones
1 -
Amazon Alexa
1 -
Apple HomeKit
2 -
Apple TV App
9 -
Applications mobile et en ligne
1 -
Apps
4 -
Arlo Go
3 -
Arlo Mobile App
462 -
Arlo Pro
36 -
Arlo Pro 2
1 -
Arlo Q (Plus)
3 -
Arlo Smart
121 -
Arlo Web and Mobile Apps
18 -
Arlo Wire-Free
30 -
base station
1 -
Batteries
529 -
Before You Buy
731 -
Can't view cameras live at all
1 -
Dépannage
1 -
Détection de mouvements
1 -
Fehlerbehebung
1 -
Firmware Release Notes
93 -
Google Assistant
1 -
Hardware
1 -
home security
1 -
IFTTT (If This Then That)
105 -
Installation
1,953 -
Iphone 14 pro
1 -
Live view
1 -
Modes and Rules
1 -
Motion Detection
2 -
Object Recognition
3 -
Online and Mobile Apps
983 -
Online und mobile Apps
1 -
Order Not Going Through... help please!
1 -
Other Discussions
1 -
Partner Integrations
4 -
Security
1 -
Service and Storage
14 -
Smart Subscription
3 -
SmartThings
71 -
Troubleshooting
8,544 -
Videos
233 -
Vidéo
2 -
Warranty & Contracts
2
- « Previous
- Next »
