Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Problems loggin in ANDROID APP using own (home) WIFI network
Reply
Discussion stats
  • 3 Replies
  • 2301 Views
  • 0 Likes
  • 2 In Conversation
TKNT81
Apprentice
Apprentice
I have a problem using the Arlo App for Android.
I am using the same phone, router and network. I did not change anything, however this problem started about a week ago. I have two different Android devices and one Apple. My two Android devices have the same problem since a week.
When my phone is connected with a cell phone network (3G or 4G) I can login my Arlo App on both Android devices without a problem.
When my phone is connected with a wifi-network I also do not have problems with logging in my Arlo App.
However when my phone is connected with my own Wifi netwok, the same network as used by the Arlo base station (via a LAN cable), I cannot log-in the App. The app freezes showing “Getting status” or the app shows “connection time out”.
The Apple app works normal (wifi connection), as the Android app used to work.
For info: all other apps on my two Android devices work properly
What can I do?
Android App: 2.4.2_17124
Arlo Base: 1.8.8.0_11528
Hardware: VMB3010r2
3 REPLIES 3
steve_t
Master Master
Master
Very strange. What ping, upload and download do you have on your home wifi?
TKNT81
Apprentice
Apprentice
Ping 24
Down 154
Up 16
So no problems regarding my internet connection.
FYI all other app's are ok on wifi and 2,3,4G
steve_t
Master Master
Master
Yeah, easily fast enough. That's so strange that it only happens on your home wifi
