Reply
Access point to existing R9000
Dwallom
Follower
I am in need of a ceiling mounted access point with poe. What models are compatible with my existing R9000 router? Can the access point use the same SSID as the R9000?
Thanks in advance!
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 2
Guru
Re: Access point to existing R9000
Can you use the same ssid as the R9000? sure.
Will it integrate like a mesh system and offer seamless roaming? Nope.
the R9000 isn't a mesh router/system. You can use the same ssid but devices will tend to be "sticky" and not roam like they would in a mesh system.
In terms of POE access points, you can view the netgear business access points that'll have some models that support POE. There's a filter to filter out those that doesn't support poe.
Wireless Access Points - Wifi Access Points | NETGEAR
CM2000-> RAXE500-> GS716v2-> WAX218-> EX8000
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 176 views
  • 0 kudos
  • 2 in conversation
Announcements
