Reply
Adobe Player Flasher Needed for Map Planning
pcmaster112
Follower
Hello Community,.
    I need some help I got a Netgear WC7600 WIreles controller today I was planning on inputing a map to get some WIFI AP's  but the screen tell me that I need to get Adobe Flash Player to run the map planner. I need some help on what to do for this issue.
thanks
Mike
Model: WC7600|ProSafe Wireless Controller
Message 1 of 2
schumaku
Guru
Re: Adobe Player Flasher Needed for Map Planning
Mike,
Afraid there is not much you can do. The Web browser makers commonly agreed to drop the NPAPI (and PPAPI) used for these plugins a longer time ago already. Any kind of work-around were made difficult if not impossible because also Adobe Flash was EoL'ed with the year 2020  and the code was rendered inop or removed.
All WC7600 wireless controllers (or matter of fact all wireless controllers) are EoL, and no updates will be available.
The controllers remain workable and manageable beyond of this limitation AFAIK.
-Kurt
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 663 views
  • 0 kudos
  • 2 in conversation
Announcements
