Reply
AirBridge Set up
tilda
AirBridge Set up
Purchased the 2 pack AirBridge. Distance between source AirBridge (my house), and target AirBridge (a workshop) is about 500 ft.
Have not set anything up yet.
Do I need to connect something like a NETGEAR AC2000 Dual Band Wireless Access Point (WAC124) to the target AirBridge with Ethernet in order to get wifi to computers and iPads at that target location?
Note: the WiFi source is generated by an AT&T modem/router in the house.
Thanks
Message 1 of 5
Accepted Solutions
schumaku
Guru
Re: AirBridge Set up
The AirBridge pair does only establish the connection, it does not have a wireless access point to connect wireless clients at the far location. The only exception is a short range 2.4 GHz radio for the local management of the device only. Said that: Yes, you need an additional access point.
Message 2 of 5
All Replies
schumaku
Guru
Message 2 of 5
tilda
Thanks for the clarification.
So, could I use a NETGEAR Wireless Access Point (WAC510) and connect it with Ethernet directly to the target AirBridge's Power Adapter?
Would that just extend the home network or would I be creating a whole new network at the target location?
Message 3 of 5
schumaku
Guru
For adding a Netgear WAC5xx or WAX6xx you need either a power supply or a PoEPoE+ switch. Be Ethernet yes, the AirBridge's Power Adapter is for the AirBridge unit only.
Message 4 of 5
hnagaraju1
Guide
 Network1=====WBC502(root)  ~~~~~~500 meters-~~AirbBridge link~~~~~~~~ WBC502(Satellite)====Network2
you can use any of Access points.
WAC500 series, (11 AC)
WAC100 series (11AC)
WAX200 series (`11AX)
WAX600 series  (11AX)
to server wireless clients in Network2 side.   500 and 600 series can be powered on with power adaptor or Poe/Poe+ switches.
Message 5 of 5
Discussion stats
  • 4 replies
  • 2423 views
  • 2 kudos
  • 3 in conversation
Announcements
