Reply
Best Practice for Setting up 2.4 & 5.0 ghz networks (WNDAP360)
booeyOH
I would like to set up my WNDAP360's to have the same SSID throughout our building. I was planning on using the WMS105 to manage them (only have 2 to start with), but unfortunately, it does not work with the 360 Smiley Sad
My question is about how to set up the SSID. Do I need to set them up different for the 2 frequencies, or can I set it up as MYBUILDING for both 2.4 and 5.0 ghz?
What is "best practice" here?
Thanks,
Bryan
Message 1 of 10
jmizoguchi
Virtuoso
Re: Best Practice for Setting up 2.4 & 5.0 ghz networks (WNDAP360)
Use different SSID for each bands.
Makes difficult use correctly to identify
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 10
booeyOH
Can you explain "Makes difficult use correctly to identify ". I am not sure I understand.
Message 3 of 10
jmizoguchi
Virtuoso
In order to choose either of bands for user.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 10
booeyOH
Ok, I get it. So the wireless card will not automatically pick the 5.0ghz band if the SSID is the same?
Message 5 of 10
jmizoguchi
Virtuoso
makes not difference.
5Ghz has less range over 2.4ghz unless you have saturated issues that needs to deal with.
person has to put TWICE on both SSID anyway for dual band wifi adapter
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 10
booeyOH
That is helpful, thank you!
Message 7 of 10
booeyOH
I didn't think about this until later, but I was hoping for one SSID throughout the whole building. So basically, you can't/shouldn't do this with dual band?
Bryan
Message 8 of 10
jmizoguchi
Virtuoso
that is bad practice.
ex "mybuidling_24" for 2.4Ghz "mybuilding_5 for 5Ghz"
also 5ghz is less range over 2.4ghz so if you loose 2.4ghz then likely will not going use 5Ghz unless you have saturated 2.4ghz other than yours causing channel interfernces.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 9 of 10
hdave
NETGEAR Moderator
You can configure same SSID on both bands if you need that way, but I would recommended you to use separate SSID for both bands so you can choose which one to connect. Also you can priorities 5GHz over 2.4GHz by adding both to your Wi-Fi connections, and saying that one is better than the other.
However if you planning to use same SSID for both bands, client will select the one which is available first. And you can use inSSIDer to see which band you are connected to as well as it will chow you which channels you are connected to.
Let me know if you have any other questions.
Thanks,
Hardika
Level3 Support Engineer
Message 10 of 10
Discussion stats
  • 9 replies
  • 26594 views
  • 0 kudos
  • 3 in conversation
Announcements
