Reply
Can I use a Range Extender in this setup?
osalliance
Currently we have a SXRN3205 and FVG318, with cable between the two. There is one area of the building that can't get wifi signal and I would like to know if a WN3000RP could be used to extend the range of the FVG318.
The SRXN3205 is the DHCP server and the FVG is just an access point.
When I try to get the RE to connect, it just sets itself up to the SRXN3205, but the signal is very weak.
If it is possible, how do I get it to connect to the FVG318?
Message 1 of 6
jmizoguchi
Virtuoso
Re: Can I use a Range Extender in this setup?
just extender, with WPA2 on main router should work fine
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 6
osalliance
The problem with that is the main router is too far away from the area that I want to cover. The FVG318 is the router that is closest.
Message 3 of 6
jmizoguchi
Virtuoso
you will need better signal with external antenna
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 6
osalliance
So are you saying that it is not possible to boost the signal from the FVG318?
Message 5 of 6
jmizoguchi
Virtuoso
If antenna disconnects then you can so if not then you know the answer
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 6
Discussion stats
  • 5 replies
  • 13944 views
  • 0 kudos
  • 2 in conversation
Announcements
