Reply
Can't Log into Prosafe WG302v2 Access Point
rvernon
Follower
Can't log into access points, I keep seeing this screen.Can't log into access points, I keep seeing this screen.Anyway to get past this window when using a LAN connection? I tried using explorer, chrome, and firefox all three give me the same window. Thanks in advance for any help you can suggest.
Model: WG302V2|ProSafe 802.11G Wireless Access Point
Message 1 of 3
JohnC_V
NETGEAR Moderator
Re: Can't Log into Prosafe WG302v2 Access Point
Hi rvernon,
Welcome to our community!
You may try resetting the AP to its factory default settings then try to access the admin page and check the results.
Message 2 of 3
JohnC_V
NETGEAR Moderator
rvernon,
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 932 views
  • 0 kudos
  • 2 in conversation
Announcements
