Reply
Can you please suggest a best wifi router for small business
KumarP
Message 1 of 6
DaneA
NETGEAR Moderator
Re: Can you please suggest a best wifi router for small business
Hi @KumarP,
You may want to check the Orbi Pro router.  Kindly access the data sheet and articles below for more information:
Orbi Pro - AC3000 Tri-band WiFi System Data Sheet
What is an Orbi Pro WiFi System?
What advanced features does my Orbi Pro WiFi System support?
DaneA
NETGEAR Community Team
Message 2 of 6
schumaku
Guru
What functionality, what features do you expect?
What's the space you have to cover ie. by wireless?
Do you need to have isolated VLANs for different user groups, ie. office, guests, IoT?
Any VPN services for remote access required?
Any VPN clients required to team-up with other sites?
Any many more questions you have to answer first.
Message 3 of 6
KumarP
Actually we are using JNR3210 wifi router and now we want to purchase new one. We will use it only for belwo 50 users and will use it in one building. Like JNR3210 configuration, can suggest new model of wifi route.
Message 4 of 6
KumarP
Thanks for your Quick Responce!
But we don't need of it, Currently we are using JNR3210 model wifi router and now we want to purchase new one. Please suggest other new model with same configuration of JNR3210.
Message 5 of 6
DaneA
NETGEAR Moderator
@KumarP,
The JNR3210 is a NETGEAR Home WiFi Router.  You may want to post your concern on the NETGEAR Home WiFI Routers Community here for further suggestions.
DaneA
Message 6 of 6
Discussion stats
  • 5 replies
  • 1366 views
  • 0 kudos
  • 3 in conversation
Announcements
