Reply
Cannot get custom field value in WAC720 captive portal
lannyho
Hi, I bought a WAC720 for guest wifi testing, I want to install my cafe and provide a free wifi access, before free wifi access, the customer need to provide their mobile no.. After hardware installation and connect to cloud, I created a captive portal and define a custom field, called Mobile No., but where can I export this information of this field in WAC720 / cloud? Kindly Advice
Message 1 of 6
Accepted Solutions
RaghuHR
NETGEAR Expert
Re: Cannot get custom field value in WAC720 captive portal
Hi lannyho
I assume you are managing WAC720 with Business Central. Once user gets authenticated with captive portal then go to monitoring page and under CP session tab you can download all the custom fields in csv format. See the attached sample screen shot for your reference.
Let know if this is what you are looking?
Thanks
Raghu
Message 2 of 6
All Replies
RaghuHR
NETGEAR Expert
Hi lannyho
Thanks
Raghu
Message 2 of 6
lannyho
Thanks your solution, however, can I restrict user to input correct type of mobile no., for example, at least 8 digital number?
Message 3 of 6
RaghuHR
NETGEAR Expert
Since it is a customer field we have made no restriction. But having said that we can think this in our next releases.
Thanks for your feedback
Message 4 of 6
lannyho
Thanks a lot, I wonder that can I modify the captive portal web page, I want to show my brand as a background in this web page, is it difficult to do it? Can you show me a guide?
Message 5 of 6
RaghuHR
NETGEAR Expert
Please refer business central user  manual here to see how you can upload logos. Refer Page 112 onwards
Thanks
Raghu
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 6302 views
  • 1 kudo
  • 2 in conversation
Announcements
