Reply
Cant connect to Netgear WC7600V2 default IP 192.168.0.250 after changing the management vlan
ITiBronx
Hi,
I am new for this and I was testing the vlan in the wireless controller.
I wrongly set the management vlan from 1 to 2.
Now i cant connect back to my wireless controller using the same default ip 192.168.0.250.
Is there any solution to connect back without factory reset the wireless controller.
Thank you.
Model: WC7600|ProSafe Wireless Controller
Message 1 of 3
Accepted Solutions
schumaku
Guru
Re: Cant connect to Netgear WC7600V2 default IP 192.168.0.250 after changing the management vlan
Depends on the environment ... using a switch with a port connecting a computer with VLAN 2 [U]ntagged, PVID 2, and another port connecting to the controller with VLAN 2 [T]agged. Voilà, now you have a simple a VLAN 2 management network.
Message 2 of 3
All Replies
schumaku
Guru
Message 2 of 3
ITiBronx
Thank you so much. Now i can login again.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 903 views
  • 0 kudos
  • 2 in conversation
Announcements
