Reply
Connect access points to a Mesh System
rallyboy
Follower
I own a mesh system AX6000 Tri-Band Orbi Pro with 4 add-on satellites (total of 5 devices) and its working greatly. I was wondering whether I could expand my coverage further with Access Points such as AX3600 or AX6000.
If thats possible, do I simply connect the AX3600 with Power Adapter directly on any of my Satellites and it works or do I need anything else?
Message 1 of 2
JeraldM
NETGEAR Employee Retired
Re: Connect access points to a Mesh System
@rallyboy
Welcome to the community!
Not sure what model you're referring to but the SXR80 which you have is only compatible with the satellite SXS80.
But if you're referring to access points such as the WAX620, then it should work with the Orbi Pro system by just following the installation guide here.
JeraldM
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 639 views
  • 0 kudos
  • 2 in conversation
Announcements
