Reply
Connecting two WAC510 to the same network
EastsideDev
My network configuration:
- Cable modem
Can I have one WAC510, connected to the cable modem, with the WAC510 set up as a router (DHCP), and the output from this WWAC510, going into my PoE switch, and have a second WAC510 connected to the PoE switch, set up as an Access Point, and have them both have the same SSID, so I don't have to switch between the two WAC510s, as I move about the location?
Model: WAC510|Insight Managed Smart Cloud Wireless Access Point
Message 1 of 3
Accepted Solutions
Retired_Member
Not applicable
Re: Connecting two WAC510 to the same network
Hi  EastsideDev,
Welcome to Netgear Community.
 The simple network setup with WAC510 you are looking for should work(Refer image attached). With same wireless configuration on both WAC510, You can move between APs. Please let us know if you face any issues.
There could be bottle necks if you setup complex wireless networks. Please share how exactly you want to setup wireless networks(configurations), So that we can help more on that.
Thanks.
Sharan
Message 2 of 3
All Replies
Retired_Member
Not applicable
Hi  EastsideDev,
Thanks.
Sharan
Message 2 of 3
Retired_Member
Not applicable
Hi  EastsideDev,
I just want to follow-up on this.  We’d greatly appreciate your feedback.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Thanks.
Sharan
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2959 views
  • 0 kudos
  • 2 in conversation
Announcements
