Reply
Email Settings for syslog not saving - WC7500
DeNeil
Email Settings for syslog not saving - WC7500 - tried different browsers - cleared cache - entered details - hit apply - looks ok - navigate away - come back - it has reverted to asterisks. Any ideas?
Message 1 of 6
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: Email Settings for syslog not saving - WC7500
@DeNeil,
Thank you for your response. 🙂
I suggest you to update the firmware from v6.5.3.9 to v6.5.5.24 then check if the same problem will occur.  You can download WC7500 firmware v6.5.5.24 here.
DaneA
NETGEAR Community Team
Message 5 of 6
All Replies
DaneA
@DeNeil,
Kindly post a screenshot of the settings you have configured.
Kindly try to reboot the WC7500.
What is the current firmware version of the WC7500?
DaneA
Message 2 of 6
DeNeil
Message 3 of 6
DeNeil
Hi
The Model is WC7500
The firmware is: Firmware version: 6.5.3.9
I have blanked out the email address for security.
After hitting apply, everything looks ok - I then navigate away from the page and come back to it and it has lost my entries.
The menu is under Configuration, System, Alerts/Logs, Email Setup
I have enabled syslog under  Configuration, System, Alerts/Logs, Logs/Syslog
I have set parameters for severity and to send E-mail to my email address under  Configuration, System, Alerts/Logs, Alarms.
Thanks
Message 4 of 6
DaneA
@DeNeil,
DaneA
Message 5 of 6
DeNeil
Great - all fixed - thank you!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2066 views
  • 1 kudo
  • 2 in conversation
Announcements
