Reply
Flashing Amber light WNAP 320
SAtechnology
I put IP addresses to our Netgear WNAP 320s so I can put them onto our WC 7520, however some are not responding to the IP address I put for them and when I look at them, above the power symbol they are either blinking both green and amber or blinking amber, green for the cycling, green for the network, and green for the wireless access. Some however, are blinking amber and green for the cycling, green for the network, and nothing for the wireless access.
Any help would be greatly appreciated!
Message 1 of 4
adit
Mentor
Re: Flashing Amber light WNAP 320
Did you try to factory default them? Once they are commited to the WC7520, the WC installs it's own firmware on the AP.
Message 2 of 4
SAtechnology
Yes, I have factory reset it, and when I push and factory reset it'll flash green for the power cycle but it'll eventually go back to the flashing amber light.
I'll it another go, is there a way to uninstall the WC firmware?
Message 3 of 4
adit
Mentor
Have you joined it the the WC yet? Yes, just default it.
Message 4 of 4
Discussion stats
  • 3 replies
  • 14640 views
  • 0 kudos
  • 2 in conversation
Announcements
