Reply
Looking for a router with Controls to easily turn On and Off the Wifi channels separately
Markd57
Follower
 Need to be able to isolate 2.4 Gig from  5 Gig signalling.
 Is there a NetGear Model that the user can easily Turn Off 2.4 G and Only Transmit 5G and then  Be able to Turn Off the 5G and turn On the 2.4 G.
Model: Dual Band
Message 1 of 2
schumaku
Guru
Betreff: Looking for a router with Controls to easily turn On and Off the Wifi channels separately
What is the real-world business case or problem you intend to resolve?
The brand new WAX204 can be operated as an access point or as a router, offering current WiFi 6 and WPA3 personal of required.
As per the WiFi 6 AX1800 Dual Band Wireless Access Point WAX204 User Manual :
p.60 "Set up or change an open or secure WiFi network", you can select the band where each wireless name (SSID) is active. "Select a radio button for a single band (2.4 GHz or 5 GHz) or keep the default selection, which is the Both radio button, to enable the WiFi network to broadcast on both radio bands."
p.70 "Enable or disable a WiFi radio" Each radio can be enabled or disabled individually, except if the very powerful Smart Connect feature is enabled: ADVANCED > Advanced Setup > Wireless Settings.
Do one of the following:
• 2.4 GHz radio. To change the settings for the 2.4 GHz radio, scroll down to the
Advanced Wireless Settings (2.4 GHz/b/g/n/ax) section.
• 5 GHz radio. To change the settings for the 5 GHz radio, scroll down to the
Advanced Wireless Settings (5 GHz 802.11a/n/ac/ax) section.
Turn off or turn on the radio:
• Turn off the radio. Clear the Enable Wireless Router Radio check box.
• Turn on the radio. Select the Enable Wireless Router Radio check box"
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 949 views
  • 0 kudos
  • 2 in conversation
Announcements
