- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Mesh WAC564 to WAX620
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi i am trying to mesh a WAC564 wifi extender to a WAX620 Wireless Access Point. The WAC564 is located in one building, with the WAX620 in another building. The buildings are approx 25 metres apart. I am unable to set up the Mesh network between the two buildings. However when both the WAC564 and the WAX620 are in the same building they do connect. What am I doing wrong? Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Mesh WAC564 to WAX620
If they connect in the same building but not in the other, I'd be betting on a signal issue. Exteriors of buildings tend to be made with materials that block wifi much better than interior walls. And 75ft between devices plus 2x exteriors walls might be to much
- Mark as New
- Bookmark
- Subscribe
- Permalink
This combination is technically supported, indeed.
The question is what else is in between the two buildings except of the 25 meters?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi the buildings are simple concrete block construction in our garden. There is nothing in between the buildings (no trees etc), just open land.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Concrete is one of the best blockers of wifi. And if both buildings have exterior walls made with concrete, its going to significantly deteriorate the signal. I'd be betting on thats why it works if they're in the same building but not once you separate them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok thanks. Perhaps I would be better installing an extender on the outside of one of the buildings to help me extend the signal? Can you recommend a suitable extender?
Thanks for your help
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Drop in or burry a network cable between the buildings (self-installable) - use WiFi APs on both sides.
