Reply
Need WN604 configured as Client for VPN conflict
DTB2
Help!!
The hotel I'm at has a conflict using the same IP as the Netgear VPN I have setup. I have a WN604 that I want to configure as a client to the hotels wireless network then connect the laptop via wire to the WN604 so I have a differnet IP on the laptop to get to the VPN. I tried seting up the client part, but don't see where it's going to know the DNS and default route on the wireless side. How exactly do I configure this .. or if the WN604 is not the correct device (it will require the same IP on the wire side as wireless) then which device do I need. Would I also need to setup/change the default route and DNS servers on the laptop (hard coded or can put to the WN604 device and it handles it????)
TIA!!
Message 1 of 3
jmizoguchi
Virtuoso
Re: Need WN604 configured as Client for VPN conflict
That is why the main VPN router should have UNIQUE IP to avoid the issues like this
you have to fix the VPN router LAN IP first to unique IP
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 3
adit
Mentor
Read my LAN Subnets NOT to Use tutorial.
Message 3 of 3
Discussion stats
  • 2 replies
  • 14099 views
  • 0 kudos
  • 3 in conversation
Announcements
