Reply
Highlighted
Initiate
Need routers which support protocol 802.11R and uses openWRT
I am looking for routers which are providing support for 802.11R fast roaming and along with them also provides support for 802.11K and 802.11V protocols. There are some SOCs which are providing support for the wireless protocol mentioned previously. Also the board should be using openWRT framework.
Please let me know if is there any router providing support for all of them.
Thanks,
Ankur Saxena
Message 1 of 2
Highlighted
Initiate
Re: Need routers which support protocol 802.11R and uses openWRT
I have found out that Netgear EX2700 supports openWRT and is based on SOC MT7620 which supports 802.11 R and 802.11K. Wanted to know whether this protocol support is there in this router model or not. And if yes, then to what extent support is provided especially for 802.11R protocol.
Thanks,
Ankur Saxena
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 6227 views
  • 2 kudos
  • 1 in conversation
Announcements
