Reply
Netgear Prosafe WG 103 firmware Upgrade Failure
aboaiad2008
Hello;
I have a WG103 Access Point ,ant while i was upgrading the firmware the power was interrupted ;
now the test LED is always green , the wireless is OFF, i cant PING or HTTP the Access Point "From my NIC of-course after configuring it with the proper Static IP configuration"
if any one has a solution for this problem please advice
thanks in advance Smiley Wink
Message 1 of 3
adit
Mentor
Re: Netgear Prosafe WG 103 firmware Upgrade Failure
It's bricked. Contect Tech Support to see if they will replace it.
Message 2 of 3
aboaiad2008
thanks for your reply
Message 3 of 3
Discussion stats
  • 2 replies
  • 14308 views
  • 0 kudos
  • 2 in conversation
Announcements
