Reply
Rejoin Wireless Controller WC7520 into stack
MLO_Dukes
We have three WC7520 that used to be configurated into a stacking, one of those were problems to sync and get information from the master.  To fix this issue we removed this one (182) from the stacking and when we tried to insert it we've got this message:
We add it as a slave connected into a Master (181).
Any advice to fix it?
Thank you.
Message 1 of 7
Accepted Solutions
LaxmankumarG
NETGEAR Expert
Re: Rejoin Wireless Controller WC7520 into stack
Hi, We explored other options but could not find a better solution then wiping out the existing configuration and re configuring everything from the scratch.
Message 6 of 7
All Replies
JohnC_V
NETGEAR Moderator
Hi MLO_Dukes,
May I know how did you removed the 182 from the stack? Did you just unplugged the cable then try to reconnect it?
Message 2 of 7
MLO_Dukes
Hi JohnCarloV,
For removing it I just click delete on Stacking tab and restarted all three Wireless Controllers.
I didn't remove any cable.
Regards
Message 3 of 7
LaxmankumarG
NETGEAR Expert
Hi,
Looks like the stacking configuration was not wiped out completely when you remove the controller 182 fromt he stacking configuration. Can you factory reset the controller .182 and try to add back to the stack?
Message 4 of 7
MLO_Dukes
Hi LaxmankumarG,
Thank you, unfortunately, I can't wipe up this Controller in this moment We will be waiting for the next maintenance window to try this.
Is this the only solution or there is another thing to do?
Best Regards,
Message 5 of 7
LaxmankumarG
NETGEAR Expert
Message 6 of 7
MLO_Dukes
Hi,
Thank you, probably this solve the problem.
Best Regards,
Message 7 of 7
Discussion stats
  • 6 replies
  • 3114 views
  • 1 kudo
  • 3 in conversation
Announcements
