- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Same SSID networks failing with multiple APs on differnet channels.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello All,
I am running into an issue adding a WAC104 to my network. The WAC104 is connected via a managed switch that connects back to a Nighthawk router. Both the Nighthawk and the AP use the same SSID--say xyzNet. Both devices are set to non-overlapping channels on 2.4, 5 gHz. So from a basic stand point all of this should work. However anything that connects though the WAC104 WiFi will seemingly loose connectivity. I don not have this issue using other wired devices going through the switch nor if i connect to a LAN port in the WAC104.
My DHCP is set up on the Nighthawk and does have a few reserved addresses. The WAC104 is set to an address in the same subnet 192.168.0.x
For the life of me I can't figure out why devices drop off the WAC 104. Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Same SSID networks failing with multiple APs on differnet channels.
If you connect the wac104 directly to the router, does it work?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Excellent question. I had not done do due the the layout but I try it!
