Reply
Setup multiple SSID's one a single AP
mohammed_ghani
Hi all
I am brand new to this forum and was wondering if I could get some advice. One of our customers has a Netgear Prosafe  WC7600 wireless LAN controller and I am having issues broadcasting two SSID's from one access point. There are several access points around the building and they broadcast the main SSID however, one access point needs to broadcast the main network plus a guest network. Is this possible? Any information will be useful.
Kind regards
Mo
Message 1 of 5
nmhTester
NETGEAR Expert
Re: Setup multiple SSID's one a single AP
WC7600 supports upto 8 SSID per AP.
you can put the AP into seperate"group" and configure that group to have two SSIDs you need.
How to create a new group and assoicate an AP to that new group :
https://kb.netgear.com/25172/How-do-I-add-an-Advanced-Profile-Group-on-my-ProSAFE-Wireless-Controlle...
How to create SSID for the newly created group
https://kb.netgear.com/25174/How-do-I-configure-a-profile-in-an-Advanced-Profile-Group-on-my-ProSAFE...
Message 2 of 5
mohammed_ghani
Hi nmhTester
Thanks for your response. The problem I have is that one of the SSID's that I want to broadcast from the access point is already broadcasted on other access points and part of another group. When I attempt to add the same SSID to another group it doesn't let me as it's already been used. I hope this makes sense.
Thanks
Mo
Message 3 of 5
RajaM
NETGEAR Expert
Hi Mo,
Welcome to Netgear Community,
1. AP will broadcast the SSID based on the group they belongs to.
2. By default all the APs will be part of basic group.
3. I believe you have all the APs in basic and you have profile "mainSSID", that is the reason "mainSSID" broadcasted from all the APs.
4. If you want to have "Guest" SSID for only one AP, then navigate to Configuration -> WLAN Network -> Select the AP which you want to have "Guest" SSID-> Choose group 1->Apply.
5. Navigate to configuration -> Profile ->Advanced -> Radio ->Edit ->Confgure "mainSSID"->Apply->Press + button-> Add -> Configure "GuestSSID"->Apply.
Please find an attachment for screen shot.
Note:
1. If you are trying to have same SSID on the same band, then controller would not allow you to configure and it will throw an error saying "SSID already exist". Having same SSID on the same band is not recommended.
2. You can create/add "same SSID" in different group or you can add same SSID on both 802.11b/bg/ng and 802.11a/na/ac.There won’t any issue.
Thanks
Raja M
Message 4 of 5
RajaM
NETGEAR Expert
Hi Mo,
We would like to follow up on this issue, could you please try these steps which @RajaM have mentioned and let us know your feedback?
If you found this solution helps, kindly change the status.
Thanks
Raja M
Message 5 of 5
Discussion stats
  • 4 replies
  • 3780 views
  • 0 kudos
  • 3 in conversation
Announcements
