Reply
Should I upgrade firmware on WAX625 - discrepancies in the release notes?
mjc775
Star
The 12/21/22 update to the WAX625 looks to have the same details as the WAX615 posted the same day. But the WAX625 previous firmware was not 10.3.1.5 - it was 10.2.6.8 (its initial release).
WAX615 Firmware Version 10.3.1.8 | Answer | NETGEAR Support
WAX625 Firmware Version 10.3.1.8 | Answer | NETGEAR Support
Message 1 of 3
Guru
Re: Should I upgrade firmware on WAX625 - discrepancies in the release notes?
I'm always a fan of waiting a little bit to see if major issues crop up in the forums. But the business releases tend to be a little more stable. So if you're currently having issues and the notes show a fix for it, I'd try it. If not, I'd wait a bit and see if others have issues before updating.
Message 2 of 3
schumaku
Guru
Which part of the list does hold you off from deploying - are you under the impression that these re fixes applicable to just one previous release?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 714 views
  • 1 kudo
  • 3 in conversation
Announcements
