Reply
Use as a Router?
JeffreyY
Guide
Use as a Router?
Is anyone using the WAX204 as a router?
I have had issues getting it to work with wired connections.
Thanks!
JeffY
Message 1 of 4
Guru
Re: Use as a Router?
1. what modem/gateway are you connecting it to?
2. what firmware is on it?
3. what actual issue are you running into? Details help more than just "issues"
Message 2 of 4
JeffreyY
Guide
Thanks for the reply.
The WAX2004 is connected to my ISP's Cable modem (Spectrum). No idea what firmware would be on that box.
I set up the WAX204 as a router (which is a selection in the setup to use either as a router or AP).
Some of my wired devices cannot connect --  was previously wired connection but now says 'cable unplugged'. Also tested several ethernet ports and shows wired adaptor disconnected.
Message 3 of 4
Guru
what spectrum modem is it?
Do all devices fail that are hardwired in?
I'm more curious what firmware is on the WAX
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1154 views
  • 0 kudos
  • 2 in conversation
Announcements
