Reply
WAC 510 after firmawre update I cannot login by my custom credentials
AlexeyPl
Follower
https://kb.netgear.com/000061180/WAC505-WAC510-Firmware-Version-8-2-1-16#
after update to this firmware I cannot login to AP, config on AP is the same as before update. But login/password is not working.
I do not want to reset AP, configuration is difficult to restore.
Message 1 of 2
JohnC_V
NETGEAR Moderator
Re: WAC 510 after firmawre update I cannot login by my custom credentials
Hi AlexeyPl,
Welcome to our community! 🙂
My apologies for the inconvenience. We may need to reset the AP back to its default settings in order for us to access the web GUI. There is no way to login on this AP unless we do a hard reset. Please always do backup your configuration.
You may also check this thread. Hope this one helps!
John
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1131 views
  • 0 kudos
  • 2 in conversation
Announcements
