Reply
WAC104 - 5Ghz channel list
lisasevern
Hi
Just purchased a WAC104 wireless AP, firmware updated to 1.0.4.9, and want to set a 5GHz channel in the 100-144 band (legal in the UK), however this option doesn't seem to be available. I've tried a few other regions and some have 149-165, but can't find one with 100-144 allowable.
Is there any way to get this band, or is this a firmware or (hopefully not) a hardware limitation?
Thanks
Lisa
Message 1 of 4
Retired_Member
Not applicable
Re: WAC104 - 5Ghz channel list
Hi Lisa,
Welcome to Netgear Community!
What was the earlier version before upgrading to v1.0.4.9? Did you see channel 100-144 when your router was just out of the box?
At first place, Clear your browser cache, re-login to see if channels are listed?
Else Can you please reset your WAC104 router once(with firmware v1.0.4.9) and check if channels 100-144 are available?(If you are okay with resetting the router)
To reset router, Refer page #44 https://www.downloads.netgear.com/files/GDC/WAC104/WAC104_UM_EN.pdf
You can save and restore configs to avoid configurations getting lost,
  • Backup configuration file -> Do factory defaults-> Clear browser cache -> Access AP GUI using IP address -> Restore the configuration file.
Meanwhile we will check this issue from our end.
Sharan
Message 2 of 4
jonathan_l
NETGEAR Expert
WAC104 doesn't support channel 100-144 (DFS channels)
Message 3 of 4
lisasevern
Damn ... *eyes lovely uncontested spectrum* ... do you know if this is a firmware, hardware or marketing limitation?
Thanks
L
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1489 views
  • 0 kudos
  • 3 in conversation
Announcements
