Reply
WAC505 looses configuration after power loss
tminimax
Hallo,
i´m using a WAC505 AccessPoint which is powered through POE. Everything is working perfect, but if i encounter a power loss, the configuraton of the wac505 is also lost. what is wrong? i'm using it in standalone config mode - no cloud...
is the ap broken?
thanks for any help
Model: WAC505|Insight Managed Smart Cloud Wireless Access Point
Message 1 of 13
Accepted Solutions
tminimax
Re: WAC505 looses configuration after power loss
yes, factory default. so i opend a replacement call at netgear support
the exchange the ap to a new one.
now everything is working
it seems that the config could not stored permanently in the chips
Message 12 of 13
All Replies
RaghuHR
NETGEAR Expert
Hi Thomas Minichmayr
Welcome to the Netgear Community. Do you know the firmware version that AP is running?
Does this happens when you do manual reboot from UI?
Does this happens when you connect AP with external power supply and reboot happens because of power shutdown?
Thanks
Raghu
Message 2 of 13
RaghuHR
NETGEAR Expert
Can you share the switch model details that you have connected your AP?
Message 3 of 13
tminimax
Hi,
the firmware is the latest (i think): V3.1.0.12
no power supply used (because shipped without) --> connected via netgear poe switch
on manual reboot the config is still available!
only if i disconect the ethernet cable oder power of the switch - the config is lost!
Message 4 of 13
RaghuHR
NETGEAR Expert
Could you please save the detailed logs from monitoring page and send it for us to debug?
Thanks
Raghu
Message 5 of 13
tminimax
the switch is a dlink (not netgear), modell DGS-1008P from d-link
other poe devices are working ok - e.g video surveillance cams...
Message 6 of 13
tminimax
i configurated the ap on monday for testing purposes
no entries about that in the log
yesterday i detached the ap and tried to bring it to its final place
no config
therefore i configurated the ap again.
today i tried to simulate the power failure and config loss again
new configuration
stupid question - how can i send you the config through this tool - only some dosc are allowed, no tar.gz file...
Message 7 of 13
tminimax
problem still vacant - any ideas?
Message 8 of 13
Retired_Member
Not applicable
@tminimax,
When the power is lost and AP configuration is reset, is there any SSID broadcast from the AP when it regains power? (either default SSID or any SSID seen)
Thanks
DavidGo
Message 9 of 13
tminimax
i have to check this
Message 10 of 13
RaghuHR
NETGEAR Expert
@tminimax do you have any update on this?
Thanks
Raghu
Message 11 of 13
tminimax
Message 12 of 13
tminimax
@RaghuHR
@Retired_Member
thank you very much anyway for your help!
Message 13 of 13
Discussion stats
  • 12 replies
  • 3169 views
  • 0 kudos
  • 3 in conversation
Announcements
