Reply
WAC510 Guest Network
hagepat
I have 2 WAC510 and 1 WAC505 access-point.
The switches I have are Netgear switches and the router is also from Netgear.
I want to create a guest network. I know that I have to create seperate VLAN on switch and access-points.
But do I have to create the VLAN on the router also?
Model: WAC510|Insight Managed Smart Cloud Wireless Access Point
Message 1 of 3
Accepted Solutions
DaneA
NETGEAR Moderator
Re: WAC510 Guest Network
Hi @hagepat,
Welcome to the community! 🙂
Yes, so that router will be the DHCP server for the Guest network.  However, if the switch has a function to create a DHCP Pool for the Guest network then configure a DHCP Pool in the switch.
DaneA
NETGEAR Community Team
Message 2 of 3
All Replies
DaneA
NETGEAR Moderator
Hi @hagepat,
DaneA
Message 2 of 3
schumaku
Guru
@hagepat wrote:
... and the router is also from Netgear.
Which Netgear router model?
Please note older Wifi Routers, Nightawk, Orbi, and Orbi Pro don't come with any VLAN support for the local LAN side.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2696 views
  • 1 kudo
  • 3 in conversation
Announcements
