Reply
WAC510 low coverage since last firmware 1.2.5.11
Stephanfo
Hi All,
Since I updated the WAC510 with the last firmware (1.2.5.11), I noticed a big drop of the wifi coverage. Any advise before to try to return to the previous firmware to test ?
Regarding my tests, I was able to cover all my house, since the update, only 2 rooms. I also did external test, but after 25 meters, the wifi is low, and all attempts to connect fail. I tried with all my 5 devices (Apple only, I guess only 5ghz), same results.
I didn't change anything in the configuration between both firmware.
Thank you for your support.
Stef.
Message 1 of 6
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: WAC510 low coverage since last firmware 1.2.5.11
Hi Stephanfo,
Welcome to the community! 🙂
Did you perform a factory reset on the WAC510 after upgrading the firmware?  If not yet, I suggest you to perform a factory reset on the WAC510 then reconfigure it from scratch in order to start clean using the latest firmware version.
Hope it helps.
DaneA
NETGEAR Community Team
Message 2 of 6
All Replies
DaneA
Hi Stephanfo,
Hope it helps.
DaneA
Message 2 of 6
donald24
Tutor
Betreff: WAC510 low coverage since last firmware 1.2.5.11
Hey Stephanfo,
did you try a reset yet and has it helped?
Message 3 of 6
DaneA
@Stephanfo,
I just want to follow-up on this.  We’d greatly appreciate your feedback.
DaneA
Message 4 of 6
Stephanfo
Hi all,
Yes, reset to defaults solved the problem. Thank all for your help.
For the information, after factory reset, the RSSI Threshold is set to -85.
Stéphane.
Message 5 of 6
DaneA
@Stephanfo,
Thanks for your feedback.  I'm glad to know that doing a factory reset has solved the problem. 🙂
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 4883 views
  • 0 kudos
  • 3 in conversation
Announcements
