- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WAC540 extremely slow login
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I'm using at home a WAC540 with web-browser control (instead of Insight).
Each time I log on to the device, it takes a minute or more (!) before the Main Menu page has completely appeared on my screen, and I can use it (and works fine).
Hard to believe this is normal, is it ??
Others have the same experience ?
THANKS.
V.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WAC540 extremely slow login
Safari & Edge also good alternatives to check with ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Chrome as well as it's Microsoft cousin Edge are suffering from the much to old issue Netgear should address almost 18 months since the problem was introduced. Once you logged in, and the URL is redirected to the /dashboard, a forced reload does typically "fix" the issue and makes the WAX5xx workable from Chrome and it's derivatives. However, this should not be required: Can't be difficult - considering it's new WAX6xx siblings members do not suffer from the Web UI problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep, Firefox brings on the main menu MUCH quicker.
Can anything be changed in Chrome settings to speed this up ?
Thanks,
V.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Don't think it's settings related. Once the Chrome is loading the /dashboard slowly, do a forced reload - et voila, Chrome does perform the UI as fast as any other browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, once the login is complete, dashboard works okay.
But with every new login, it's the same get-a-coffee moment...
- Mark as New
- Bookmark
- Subscribe
- Permalink
