Reply
WAC720 Back to standalone
djccy
My English is very poor, this is translated by google. Please understand!
WAC720 requires Back To Standalone and runs multiple times in Console
Firmware-upgrade-tftp firmware.tar 192.168.1.200
The firmware can be successfully uploaded, but it is not always possible to switch back to standalone mode.
Can anyone help me? Thank you!
[root@Netgear /root]$ firmware-upgrade-tftp firmware.tar 192.168.1.200
Starting an Upgrade
*** Getting firmware file firmware.tar using tftp server 192.168.1.200 ***
killall: dhclient: no process killed
*** Getting firmware file firmware.tar using tftp server 192.168.1.200 done***
/bin/firmware-error-check: Validating upgrade.tar.
board_type not defined - allowing installation
-: OK
*** Bringing down Ethernet Interface ***
killall: syslog: no process killed
killall: snmpd: no process killed
killall: hostapd: no process killed
killall: telnetd: no process killed
killall: udhcpc: no process killed
killall: nmbd: no process killed
killall: lighttpd: no process killed
killall: php: no process killed
killall: ntpd: no process killed
killall: klogd: no process killed
killall: sleep: no process killed
mkdir: cannot create directory '/lib/modules/2.6.15--LSDK-7.3.0.385': Read-only file system
killall: hostapd_app: no process killed
killall: hostapd_mgr: no process killed
killall: stats_mgr: no process killed
cp: cannot stat '/usr/bin/led-op': No such file or directory
cp: cannot stat '/lib/ld-uClibc-0.9.29.so': No such file or directory
cp: cannot stat '/lib/libcrypt-0.9.29.so': No such file or directory
cp: cannot stat '/lib/libm-0.9.29.so': No such file or directory
cp: cannot stat '/lib/libuClibc-0.9.29.so': No such file or directory
Model: WAC720|2x2 Wireless-AC Access Points
Message 1 of 4
Accepted Solutions
DaneA
NETGEAR Moderator
Re: WAC720 Back to standalone
Hi @djccy,
Welcome to the community! 🙂
Just to verify, was the WAC720 managed by a wireless controller before?  Kindly try to factory reset the WAC720 after the TFTP firmware upgrade.
Let me share the forum thread below and hope it helps:
https://community.netgear.com/t5/Business-Wireless/WAC730-Back-To-Standalone-Mode-Via-Console/td-p/1...
DaneA
NETGEAR Community Team
Message 2 of 4
All Replies
DaneA
NETGEAR Moderator
Hi @djccy,
DaneA
Message 2 of 4
djccy
Thank you!
1, yes, WAC720 was previously controller management. Now the controller is broken.
2, I have to press the reset button to restore it to factory settings, but this is not useful
3, successfully uploaded many times firmware, but can not always run new firmware
I have read the post you shared. But I don't understand the following:
(So I found a command on the console to simply TFTP the .tar file to the /tmp folder on the WAC730. Then once it was in place I ran another script called firmware-upgrade or something like that pointing it at the same .tar file )
He said after uploading the firmware to /TMP. What commands are entered to run the new firmware?
Thank you again!
Message 3 of 4
DaneA
NETGEAR Moderator
@djccy,
I apologize for the late response.  Let me share the forum thread below:
DaneA
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2371 views
  • 0 kudos
  • 2 in conversation
Announcements
