Reply
WAC720 - no network link - units working fine
ratherman
Luminary
We have 12 of these at various sights - all working fine with te latest firmware.  We just noticed that on one of the units the network led is not on.  The unit works fine and the POE switch indicates no issues.  Is there any reason the light should not be lit - os is it just a malfunction?  Would this be covered under warranty?
Model: WAC720|2x2 Wireless-AC Access Points
Message 1 of 3
DaneA
NETGEAR Moderator
Re: WAC720 - no network link - units working fine
Hi @ratherman,
I suggest you to perform a factory reset on the WAC720 wherein the network LED does not turn on.  Then, reconfigure the settings from scratch and observe if still the network LED will not lit up.  If ever the network LED still did not lit up then there is hardware fault on the access point.
Let us know the result.
DaneA
NETGEAR Community Team
Message 2 of 3
DaneA
NETGEAR Moderator
@ratherman,
I just want to follow-up on this.  Were you able to perform a factory reset on the WAC720 then reconfigure the settings from scratch?  If yes, does same problem occur wherein the network LED does not turn on?
DaneA
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1430 views
  • 0 kudos
  • 2 in conversation
Announcements
