Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Reply
WAX218PA Firmware Updates
maddhater
Tutor
Is this product discontinued? I just bought it and I can't find any resources even the firmware on the website.
Message 1 of 6
Accepted Solutions
Guru
Re: WAX218PA Firmware Updates
The WAX218PA is just a wax218 with a power supply.
You can find guides, firmware here: WAX218 | WiFi 6 Access Point | NETGEAR Support
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 6
All Replies
Guru
Message 2 of 6
maddhater
Tutor
What's the difference between MIB and Firmware?
Message 3 of 6
maddhater
Tutor
Looks like the firmware isn't compatible. Any advice?
Message 4 of 6
Guru
MIB is more for rolling it out to your whole system. Use the firmware image.
Try an earlier version instead of jumping to the latest.
Message 5 of 6
Guru
also make sure you extract the file before trying to upload it.
Message 6 of 6
Discussion stats
  • 5 replies
  • 6207 views
  • 5 kudos
  • 2 in conversation
Announcements
