Reply
WAX610 login fails
WAX610 login fails
Hello everyone,
I bought a used WAX610.
Unfortunately, after connecting to the "Setup SSID" on the GUI in the web browser (192.168.0.100),
i cannot log in with the standard login data ("admin" - "password" or "admin" - "1234").
I'm always told that the login details are incorrect.
I googled "whatever it takes"... found nothing.
I've already tried this 30-30-30 method... Same result 😞
It can't be that the standard login data is incorrect in the "initial setup mode"!
Is there a solution?
Many greetings and thanks
Hallo zusammen,
ich habe mir einen gebrauchten WAX610 gekauft.
Leider kann ich nachdem ich mich mit der "Setup SSID" verbunden habe auf der GUI im Webbrowser (192.168.0.100) nicht mit den Standard LogIn Daten ("admin" - "password" oder "admin" - "1234") anmelden.
Mir wird immer gesagt das die Login Daten falsch sind.
Habe gegoogelt "was das Zeug hält"... Nichts gefunden.
Habe diese 30-30-30 Methode auch schon versucht... Selbes Ergebnis 😞
Kann doch nicht sein das im "Ersteinrichtungsmodus" die Standard Login Daten falsch sind!
Gibt es eine Lösung ?
Viele Grüße und Danke
Message 1 of 9
Accepted Solutions
Re: WAX610 login fails
Hello everyone,
First of all, thank you very much for your time and wanting to help, maybe also curiosity: slightly_smiling_face:
The WAX610 is completely fixed!
Login was not possible, the previous owner had probably assigned a different password but left the standard SSID...
By chance or desperation I triggered the reset button in quick succession...
That must have booted the backup FW...
Login worked
Then there is the non-functioning LAN connection...
The cooler between the housing and the circuit board was probably not sitting properly on the circuit board. (short circuit)
After a new correct "assembly" the LAN connection now works.
Wishing everyone a Merry, Blessed Christmas and a Happy New Year 2025 at the end of the year
Andre
Hallo zusammen,
ersteinmal vielen Dank für eure Zeit und helfen wollen, vielleicht auch neugierde 🙂
Der WAX610 ist komplett gefixed!
Login war nicht möglich, Vorbesitzer hatte wohl ein anderes Passwort vergeben aber die Standard SSID gelassen...
Durch Zufall oder Verzweiflung habe ich Resetknopf schnell hintereinander getriggert....
Das muss wohl die Backup FW gebootet haben...
LogIn klappte somit
Da ist dann noch der nicht funktionierende LAN Anschluß....
Der Kühler zwischen Gehäuse und Platine saß wohl nicht richtig auf der Platine. (Kurzschluß)
Nach neuer richtiger "Montage" funktioniert der LAN Anschluß jetzt auch.
Wünsche Allen zum Ende des Jahres, eine Frohe, gesegnete Weihnacht und einen guten Rutsch ins neue Jahr 2025
André
Message 8 of 9
All Replies
schumaku
Guru
The complete WAX610 documentation for your convenience.
Keep in mind the default LAN IP 192.168.0.100 is active only if the AP is not connected to a LAN port on a common router and usually assigning an IP config to your WAX.
In case this WAX610 was configured to Insight before, and the former owner config including the location specific admin password is assigned once the Internet connection does become available.
You might need Netgear Support for assistance for removing your WAX610 (based on the serial number), becuse only the fomer admin can easily remove devices from his account -> How do I remove a device from my Insight account?
Message 2 of 9
Good morning,
thank you for your answer and time 🙂
Since I have already successfully configured a 610Y and a 615, at least they work for me 🙂 I'm just at a loss with this AP.
Thank you very much for the documentation, but it hasn't helped me so far.
What you say about the IP is correct, unfortunately when connecting to my network the LAN LED remains dark and no connection is established.
When I connect the AP to my PoE switch the same thing.
The former owner wrote to me that he had deleted the switch from his Insight, but also had difficulties setting up the AP. That's why I first tried to access the switch via WiFi to log in.
As already mentioned, I can connect successfully with the initial setup SSID and the printed key, but unfortunately I keep getting rejected when logging in.
Even in the Insight program I can "initially configure" everything but it can't get a connection to the AP.
I'll try to summarize it:
LAN LED: dead
WiFi: works Login with "admin" and "password": fails (I'm told incorrect data).
Insight connection doesn't work because there is no LAN.
Since I can't get a LAN connection, Insight can't do anything?
Sorry, my English is a little rusty and google try to help me 😄
Message 3 of 9
schumaku
Guru
If the LAN LED (this is a link indicator!) remains dark, and even more if a PoE+ (802.3at is the minimum required for the WAX610) switch or injector I would double and tripple check the wiring, the cabling, the patch cords, ... in most case, this is a Layer 0 (== physical connection) issue.
Sure, this could have been the reason why the original owner had sold it.
Ich würde das mal mit dem Verkäufer diskutieren, die Vermutung liegt nahe ...
Message 4 of 9
Yes, he sold it on classified ads as defective..... Can't do anything about it...
I just don't think he came up with it via Insight when asked before buying...
I used different cables and even had it directly connected to the Netgear GS316EPP, no LAN lights up...
The AP has 4 headers inside. Can you do something via serial?
Or maybe the LAN port is deactivated because the AP is still in the basic setup?
I think I read something like that once...
However, it's strange that I can't log in.
thank you all in advance
Ja er hat es auf Kleinanzeigen, als defekt verkauft..... Kann da schlecht was machen...
Nur das er, auf Nachfrage vor dem Kauf, per Insight drauf kam, glaube ich nicht...
Habe verschiedene Kabel benutzt und sogar am Netgear GS316EPP direkt dran gehabt, kein LAN leuchten...
Der AP hat im Innern 4 Header kann man da per seriell was machen ?
Oder ist vielleicht der LAN Port deaktiviert weil der AP noch in der Grundeinrichtung ist ?
Ich meine sowas mal gelesen zu haben....
Dennoch ist es dann komisch das ich mich nicht einloggen kann.
Danke schonmal euch allen....
Message 5 of 9
UPDATE
Good morning,
Is it possible that if you “trigger” the reset several times, the AP loads the backup firmware?!
After opening and detaching the board to check the UART assignment, the AP went a little crazy...
The antenna cable also came loose...
No, I didn't short-circuit anything...
All interventions were carried out without voltage and I was grounded...
Connected the antenna and closed it again... Then the AP didn't want to boot...
I freaked out a little with the ballpoint pen and then did the reset *laugh*
It then booted and I was finally able to log in with "admin" and "password"....
So far so good....
But the LAN connection is still dead 😞
So if anyone else has an idea, please give it to me.
Best regards
Andre
Moin,
kann es sein das wen man den Reset mehrfach "triggert" das der AP die Backup Firmware lädt ?!
Nach dem öffnen und lösen der Platine um nach der UART Belegung zu schauen, spielte der AP ein wenig verrückt...
Antennenkabel hatte sich auch dabei gelöst....
Nein, habe nichts kurzgeschlossen...
Jegliche Eingriffe wurden Spannungslos vorgenommen und ich selbst war geerdet...
Antenne angeschlossen und wieder zugemacht ... Dann wollte der AP nicht booten...
Bin ein wenig mit dem Kugelschreiber dann am Reset ausgerastet *Lach*
Er bootete dann und ich konnte mich endlich mit "admin" und "password" anmelden....
Soweit so gut....
Der LAN Anschluß ist aber weiterhin tot 😞
Also wenn noch wer eine Idee hat, gerne, her damit.
Viele Grüße
André
Message 6 of 9
schumaku
Guru
Hallo André
Die Pins mit dem UART auf allen Negear Geräten sind im Netz gut dokumentiert, zum Beispiel hier https://gist.github.com/davewongillies/6481138
Das Konolen-Port (anders als zB auf den Netgear Managed Switches) ist bewusst nicht nach aussen geführt da nicht für den Endnwender vorgesehen.
Auf einem ganzen, normal funktionierenden AP wie den WAC2xx, WAX6xx und den WBE7xx ist der Ethernet Anschluss immer aktiv, und lässt sich auch nicht aus- oder einschalten.
VIel Spass und Erfolg bei "Jugend Forscht".
Grüsse
-Kurt.
Message 7 of 9
Hello everyone,
Login worked
Andre
Hallo zusammen,
LogIn klappte somit
André
Message 8 of 9
RennaD
NETGEAR Moderator
Hi @SequentialOne,
Welcome to the NETGEAR Community! 🙂
We are glad to hear that everything has been sorted out. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Wishing you a wonderful holiday season and a happy New Year.
Have a lovely day,
RennaD
Netgear Team
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1034 views
  • 6 kudos
  • 3 in conversation
Announcements
